This command configures the time period a key will be active.
| keychain_name | Specifies the name of the keychain. |
| key | Authentication key entry. |
| key_id | Specifies the unique identifier within a keychain. Range is 1-65535. |
| active-lifetime | Specifies the time period the key will be active. |
| local | Specifies the time in the local time zone instead of UTC. |
| start | Specifies the start of the time period. |
| start_time | Specifies the date and time the key will become active. Format is YYYY-MM-DDThh:mm:ss. |
| end | Specifies the end of the time period. |
| end_time | Specifies the date and time the key will stop being active. Format is YYYY-MM-DDThh:mm:ss. |
| duration | Specifies the length of time the key will be active. |
| seconds | Specifies the duration in seconds. Range is 1-15552000. |
| maximum | Specifies that the key will be active for 180 days from the start time. |
N/A.
Use this command to configure the time period a key will be active.
The following command configures the keychain active lifetime:
configure keychain ospfv3-keys1 key 3 active-lifetime local start 2021-08-01T00:00:00 end 2021-09-01T00:00:00
This command was first available in ExtremeXOS 31.3.
